BigPip
Today I was driving in some super cold Florida weather today with the heater on and after about 15 minutes of driving the fan stopped blowing and the display on the Climate Control looked like it rest- All the lights came on then turned off and finished with saying 90 Vent just like I had it but it wouldn't do anything. Also, the Air Bag Light (SRS not suspension) stayed on then disappeared after a few minutes then would come back on. after about 5 minutes it started flashing like normal( I believe, I didn't check to see if it was the same code it usually flashed) and just as I got the car home the heater started to work again, or should I say the fan turned back on. I ended up parking it and pulling the battery terminal.
The Last thing I did to car:
Air Bag light was flashing code 35 I believe, whatever code it was the fix was typically the ground wire behind the pass. side headlight. Made since to me because I am using the same ground for my projector lights. I took the bolt out, wire brushed the metal and the ground wire eyelet and reattached. I DID disconnect the battery first and once I reattached it and started the car I didn't get the original code any longer but a new one. Besides that, I set the clock this morning on the display and about 2 minutes later is when the problems started.
What is happening to the poor thing?
