Patroned_LS
sup guys
newbie here. I just upgraded my brakes and replaced a master cylinder due to leakage. I always had a high pitched sound which i always though was a leak at my intake manifold. when i was testing the master cyinder and brake booster i heard the high pitch whistle/whining change pitch. before ignition, i pumped the brakes to stiffness turned the car on and pedal would lower so i know booster is good. this is leading me to believe the vacuum line or the check valve is faulty. thing is i tried to follow the vacuum line to check valve but im not familiar with the lcation. the manual says its located int he aspirator inline with the hose. havent had the time to get back in their, was just wondering if anybody here knew where the check valve is exactly and how difficult it is to repair. thanks in advance
