Front Door 5x7 stock to 6.5 seperate component speakers adapter where to get?
jgscott
Atlanta
Ok can someone tell me where I can get a adapter/spacer plate that will also allow me some spacing depth, to change and mount 6.5 separate Component speakers with a separate 6.5 mid speaker and separate 1" Tweeter in the front Door that has the stock mount 5x7 speakers.
Any links would be appreciated. Thanks.
Well thanks as you always help me on this one but........ my confusion is that I didn't see any that have a mount for separate 6.5, separate 1" tweeter.
I put component speakers in my old 2000 and mounted the tweeters opposite the mirrors. I just don't remember the size of the woofer....
yeah they only make them offset with a tweeter mount for 5.25 comps in 6x8. the only offset 6.5 with tweeters are for 6x9s
there just isn't enough room for most brands of components to fit side by side. you're already having to squeeze in the larger speaker and for it to fit it has to be in the center of the adapter...
if you follow the very first result that I linked you to, its for the scosche version, it is about as offset as you can get as you can clearly see, i doubt that there would be room for even a small tweeter to fit there, but at least you could try... might work with a little dremeling of the OEM spacer mount.
this leaves you with two simple options... most good to really great sets of speakers also have the option to mount them coaxially, like you unscrew a bullet shaped adapter from the center of the woofer and screw a post on to mount the tweeter too. the other option would be to remove the grille from the door panel and mount the tweeter into the extra material around the speaker but still under the grille...
