Will these rims scrub ???
antonio fuller
Decatur, Georgia, United States
This should help.......
From factory 7" wheel at 60mm offset....
Your new wheel will have the following chracteristics:
The clearance from stut housing to the inside of the wheel will be 3mm MORE
The outside edge of the wheel will EXTEND an extra 41mm
The wheel, not including the tire, will stick out just over 1 1/2" more than the factory wheel. Measure the distance from the edge of the fender to the edge of the wheel and you'll see where the new wheel will sit.
There's another website somewhere (in picture format) that will show you how far the wheel will stick out too... I can't find it right now tho :(
Thanks I don't think I'm going to get them I don't want anything that's going to stick out the ls suspension is soft and on my 01 it scrub the fender and fup tires and the fender edge not to talk about bearings that because of how it's set up I has to replace the hubs all around
I would replace all your suspension parts before you start putting big heavy wheels on.
Just looked it over sounds good but I got a few questions
So how do I pull all the lighted parts off I have removed the dash before but even with that I didn't pull the bottoms off is this a pretty simple process
read his thread.. it will answer all your questions
