Blueberryyum02
The title says it all what is the part number for this connector. When I first bought the car I noticed that this connector, look as if someone was probing it, by the signs of nicks and cuts on the wire jacket.
This morning I was replacing a hose clamp on the aux pump, and the brown/blue wire came off.
Now from my previous threads I been chasing a no heat situation after replacing every piece of plastic including the degass bottle.
No matter where I set the temp control it on blows cold air,
So in a quick fix situation I took a paper clip stuck it down in the opening where the wire broke from this connector and the heater core hose on the passenger side got to hot to touch,
I thought about what Joegr said in a different post that the 12 volt is constant and the PCM switches ground on and off.
That brown wire is ground and I think it's ground for the passenger side the other brown wires look just about the same like there holding by a few strands.
I think with all the recent work in that area it may have taking its toll on those few strands.
