Going to flush my power steering, do I need to add back the friciton modifier?
Kumba
Tampa
So the title pretty much says it all. Going to flush the power steering fluid. Friction modifier was put in around 60K miles for the whining noise. Should I plan to add another bottle when I fill it again?
Also, I'm assuming I can just pop the lines on the rack and turn the wheels from lock to lock to 'flush' it into a bucket. Then refill and turn from lock to lock to bleed it. Then just run it and fill it until it takes no more fluid. Anything I need to know or is that pretty much it?
I changed my fluid (not as comprehensively) last year and only added 1/2 the bottle. The noise returned over the winter months a few thousand KMs later. I added some more (almost full bottle used at this point) a few weeks back and it has finally diminished. It could be due to the warmer weather though :confused:
Why not disconnect the return hose that goes into the reservoir, direct into a bucket, run engine and refill on the go with a helper?
Guess I could do that. Be somewhat of a pain to reconnect the hose without a mess. Guess I could drain the resevoir again before hooking up the line after flushing.
...Also, I'm assuming I can just pop the lines on the rack and turn the wheels from lock to lock to 'flush' it into a bucket. ...
If you do this, get new o-rings.
That is typically how I have done it with other vehicles.
Do not forget to keep working the steering wheel back and forth all the way lock to lock during the flushing process. This is a job where you need a helper to keep adding fresh fluid to the reservoir - you can't let is suck any air during the flush procedure.
Reservoir it is. Hopefully a few quarts will get it done.
