Aug 3, 2013 #26 dnsherrill Dedicated LVC Member Joined Aug 18, 2012 Messages 2,626 Reaction score 109 Location Raleigh Denna said: dnsherrill, Like these ... ? Click to expand... --- yep, if you're turning bolts manually like I am, just be sure to give it all you can
Aug 4, 2013 #27 D Deleted member 20330 Guest dnsherrill said: --- yep, if you're turning bolts manually like I am, just be sure to give it all you can Click to expand... dnsherrill, A long torque wrench should help make it easier, correct ?
Aug 4, 2013 #28 D Deleted member 20330 Guest racecougar said: The pictures that RockAuto shows for those part numbers look just like the stock calipers. Post pictures of the calipers you bought. Click to expand... racecougar, I just realized the caliper bracket is separate from the caliper. The caliper shown is correct.
