New fords with 5x108 bolt patterns
soccer2live
houston
Has anyone looked into the new ford fusion rims? they are 5x108 and don't look too bad. If anyone has any on their car could you post pics? Will offsets work for our cars? lowered or not lowered?
I look at them every day....the 5 spoke ones....I don't think they would quite look right.
Not that I haven't thought about it.
Someone posted some a while back in the C-List finds section.
That was probably me, since I was trying to sell mine off my new fusion. They have the same bolt pattern, hub size, and have a high offset like the LS. The only major difference is the lug type. The LS uses a flat washer style, while the newer fords use a acorn shape bottom.
The 2012 and newer Focus also has the 5 x 108 mm bolt pattern.
For information sake, here is a list of late model cars that share the LS bolt-pattern:
Ford
Escape___2013-2014
Focus___2012-2013
Fusion___2013-2014
Taurus___1986-2007
Thunderbird___1989-1997
Thunderbird___2002-2006
Transit Connect___2010-2013
Windstar ___1995-2003
Lincoln
Continental___1991-2003
Mark VIII___1993-1998
MKZ___2013-2014
Mercury
Cougar___1989-1997
Sable___1986-2005
Monterey___2004-2007
Jaguar
S-Type___2000-2008
X-type___2002-2008
XF___2009-2014
XJ___2004-2013
XK___2007-2013
Land Rover
Evoque___2012-2013
LR2___2008-2013
Volvo
C30___2008-2013
C70___2001-2013
S40___2005-2011
S60___2001-2013
S80___1999-2013
V50___2005-2012
V70___2000-2013
XC60___2010-2013
XC70___ 2001-2013
XC90___ 2003-2013
^^ can you confirm that the evoque has 5x108? I've seen sets on eBay and some say 5x108 and some say 5x120. So then I checked a site I know that sells LR wheels and the evoque ones were listed as 120 so I was wondering where you look to know for sure that they are 108.
Thanks
Sorry, just circumstantial evidence is all I have. I used The Tire Rack website initially. As a double check, I just did a look-up through Discount Tire Direct's site and it came up as 5x108mm as well.
The Evoque is based off of the LR2's platform so most likely it also shares the same bolt pattern as well.
Speaking of wheels, are you still considering selling your set of LSE wheels?
... Don't forget to verify if you'll need some Hub Centric rings for aftermarket rims.
... Some wheels are non-Hub centric (lug centric) by design, do your research ...
... For me...Still searching for a set of "concave rims" with a mean-looking offset.
. . . Vossen wheels !!! Check out those wheels @Y0uTube !! I Love that depth !! . . .
Them are Silo's
this is a Grain Elevator, you'll commonly see them by rail road tracks.
additional reference...
Yeah... Back to the 5x108 bolt pattern. I did find an ad with concave wheels matching the bolt pattern and tried to contact the company directly; but no reply.
Just recently I did come across an ad also w/ matching 5x108 pattern from Calibre Wheels (CC-V Alloy).
If anyone happens to inquire more or actually orders let us know at LVC about your order...thanks from me.
