m1bttltnkr
This is for my 01 ls v8. I got code 1633. The car runs and drives just not optimal. The power seats don't work and even after using the key to unlock the doors the alarm will go off. The fuse #7 was replaced and the car ran like a dream until the car was shut off then the fuse blew again. It has a 5amp fuse like its supposed to. The battery has been replaced. The alternator puts out a steady 13.9 volts. All the chassis grounds are freshly cleaned and sanded. The car will shut off at random times but start right back up. The mirrors won't move either. Is there any particular connection problems that are common with these symptoms?
