Aftermarket Receiver Fitment
  • Thread starter Thread starter Deleted member 20330
  • Start date Start date
D
Guest
Does anyone have any recommendations on installing an aftermarket Double DIN receiver in a Gen2 ?
Does there need to be a special cable to connect the receiver to the OEM amplifier ?
Is the "Metra 95-5817" the recommended installation kit ?
I used this harness with the factory amp:
http://www.ebay.com/itm/PAC-ROEM-FR...Parts_Accessories&hash=item3a6669fbd5&vxp=mtr
I ended up using the trim piece that came with my Pioneer double din unit. You do have to relocate the air bag module which most place just to the left of the head unit. You also need to get creative on securing the unit and I did so with mondo zip ties...
And check out these gems:
PART 1: http://www.youtube.com/watch?v=koxQj9BN6Po
PART 2: http://www.youtube.com/watch?v=3fmxueNQHpI
Excellent videos, although I'm now regretting thinking about replacing the OEM headunit.
Did you think it would end up being that involved ?
How did the woodgrain frame come off ?
What do you estimate the total installation time was (excluding the rear view camera) ?
what do you mean get creative with securing it. did you not use an install kit. its funny i saw this post as my double din arrives in the mail today. and this is what i will be doing all afternoon. I was unaware of the relocation of the air bog module as well. this should be interesting.
@denna I started a thread asking about dash kits for double dins. the metra you listed was suggested. its the one i purchased as well. i can let you know later tonight or tomorrow how it worked out.
after watching the first bit of the video im a little saddened by now.
It's TOTALLY worth it to do the head unit, IMO. Just that made the system sound tons better. Because the display center very easily pops straight up, you end up with a nice amount of room to work with. The woodgrain trim surround has two screws which are directly beneath the climate control module. Be gentle and use a trim removal tool if you can, but the climate module pops out really easily without having to remove the knobs/buttons if you have heated seats. Remove the screws and then (if you have one) use the pry tool to release the clips on the trim ring. I tend to work a little at a time, first around the shift knob being aware that there's a ground wire that will need releasing near the shift knob on the trim surround. It has some slack, so just be ready. The clips are located kinda mid shifter area one per side and then towards the center of the stereo hole one per side. Just take your time and be gentle because the edges of the trim piece are fragile. Try to get the tool more into the center of the trim surround to avoid chipping the edges.
Once you go in there a time or two, you'll find it absolutely no big deal. There's plenty of metal supports in the dash to get a nice, snug fit with big zip ties. It just takes patience... but it is monumentally worth it.
I ended up doing this twice because I did just the head unit and speakers and then decided on new amps, woofer enclosure and new wiring. I did not bother with satellite radio or a backup camera because I'm into MP3s and don't care. Backup camera on an Aviator/Navigator, sure. On an MK8, not for me.
If you think that you may ever wish to upgrade the amp, you may consider running your RCAs and remote turn-on to the amp tray in the trunk. Not difficult and you'll have everything there for the future. There's a great cable tray just beneath the carpet that I ran all my stuff through next to the passenger seat except the 4 AWG for power from the battery. There's plenty of room in there for speaker wires and RCAs. This way, unlike me, you won't have to uninstall/reinstall the head unit for this upgrade like I did.
The head unit install time with the JBL adapter is really probably a couple hours max, most of which I spent on the best way to route the zip ties. I took my time with my entire system install so as to solder everything, take great care with my aging trim pieces, run the power thru the passenger side firewall to the amps, etc.
Lastly, if you just do the headunit and don't plan for future upgrades, it is MONUMENTALLY easier to remove the trim surround and access the head unit for redoing because now you're a pro. Also, my second attempt at securing it was much better. My airbag unit fit so snugly to the left of my head unit that I don't think it needed securing. It's covered with a neoprene type material and is very light.
To me, any upgrade to the aging stereo system is totally worth it. The speakers are super easy to upgrade, even if you don't do the wiring just yet and are totally worth it.
Good luck! If I left anything out, I'll try to check back here. Also, Trippen is serious when it comes to stereo installs and very likely has excellent troubleshooting advice for you. This is just how I did mine.
Trippen, I bought a couple of install kits none of which did the complete job. I did the basic side 'filler' piece but it's wide open in the mounting hole except for the bottom support from the original head unit. I had to get creative. No big deal. I'm sure that someone has a better way to do it. This just happened to work for me. Because you also need to shave a tiny bit off of the plastic trim to insert the aftermarket HU, it creates a nice, snug fit. My HU doesn't move at all, no matter what I do or how I drive.
Also, the air bag module sits on a bracket against the firewall and has ONE screw. Just remove it, remove the bracket and place the unit perpindicularly to the left of the HU.
I might also suggest disconnecting the battery, too.
So in my ride. there was no air bag module also found the kit to be worthless. as well. i have some pics but ill be posting those in my own thread for now. I personally would not waste the money on the kit. since you will need to do some mods already to make the double din fit you might as well fashion some spacers or accept the gaps. I had two of my friends basically kick me out of my own ride and said they were gonna do this install. which is odd because i typically do all my installs. their solution while inventive is only in place till we come up with something better. at first glance tho it looks pretty nice
http://www.lincolnvscadillac.com/forum/showthread.php?90112-96-Double-Din-Meh-its-in-there
The last time I tried to fit an aftermarket receiver (on another car) I had to sand the sides of the cavity with a file. A Dremel tool would have saved me at least an hour of filing.
I was thinking of installing a JVC KW-HDR81BT, but I'm not sure the 7 3/16" width will fit.
Also, I'd prefer not to have a noticeable gap around the head unit.
Are gap kits available ?
I bought a Kenwood trim ring and then the Pioneer also came with one. It installs right to the edges of the stereo, so my unit has no gaps.
http://www.ebay.com/itm/Kenwood-tri...967?pt=LH_DefaultDomain_0&hash=item257e9df4b7
I think for fitment that I used the side pieces on the Metra kit but cut the bezel off because I didn't need it.
http://www.ebay.com/itm/LINCOLN-CAR...Parts_Accessories&hash=item20cab535c1&vxp=mtr
Hot*Mk8,
Wow, that's purple !
Exterior paint to match ?
