Aviation
So I got this code that says cylinder 3 misfire. It has only happened a few times when it rains heavy and I take the car out. It will sputter. I can let it dry and 2 hours later no signs of an issue at all. So it rains again, and again it happens and the check engline light is on. I get the cylinder 3 misfire code. Apparently this is usually an ignition coil or spark plug issue.
So i try to pull the plug. Also, not sure which cylinder is 3, dont know how they are numbered.
I unhook the connector, pull out the part, and it is brass. Not a rubber boot like the pics. Also the connector that goes onto it does not have the protective piece on it. Maybe thats the issue when it rains?
There is supposed to be a plug under the coil, but i do not see that when i pull the brass piece out.
I will post pics shortly. Any help?
