dogsled
I have a 2003 Lincoln LS, V6, 110K miles, 2nd owner. It was my wifes car, she bought it with about 30K miles. About 15K miles ago it started throwing codes for misfires and coils and went into fail safe mode. So I did some research, saw all of the issues with the coils and valve cover gaskets. I replaced all 6 coils (from RockAuto, not sure of the brand) the valve cover gaskets (felpro) and plugs (bosch platinum) at that time. There was an oil leak on the passenger side. Not long after that, it threw another coil code (thankfully for the driver side so easy to replace), so I took one of the old ones and replaced the one that was throwing the code (I have my own scanner) and all was well until recently. Now it has started going into fail safe mode and throwing codes for the throttle body stuck open, throttle body stuck closed, throttle position sensor and throttle body mod actuator, and low fuel pressure. I have misplaced the paper that had all of the numeric codes, but that is a summary of the issues. Given that the majority of the codes were throttle body related, I picked up a throttle body from a salvage yard from a 2011 Crown Vic with 30K miles. Put that on and still codes and going into failsafe mode. Now I only get the throttle body actuator code when it goes into fail safe mode. I have noticed that it misses when rev'd up to about 3000 rpm sitting in the drive way with it in park (not sure if it did that with the old throttle body or not). It is not throwing any codes for coils or misfires and the misfire counts for all cylinders are zero according to the scanner. I have read that it could be coils causing the erroneous throttle body messages, so I'm wondering if that is it given the miss. Here are the questions that I was hoping someone could help me with as I am at my wits end with this car.
Is there an electronic or printed version of a shop manual available for the LS? I have seen a few diagrams online that look like they came from a manual, but no source for a manual.
Can the coils be tested? Is so how? I have checked the resistance on the two pins and all of the coils that I have seem to be about the same, new and old.
That low fuel pressure code has me wondering if this could possibly be caused by a fuel pump failing or clogged fuel filter?
I have not ohm'd out the harness or checked any of the voltages at the throttle body, but my scanner will record data about throttle commands and position and is does change when recording data and pressing the pedal.
Is there a procedure for stress testing the coils? I have access to an oscilloscope and multimeters and my actron scanner.
The miss only occurs at about 3K rpm, it idles fine. Seems to throw the codes when under hard acceleration. Any procedures or tips on how to check any of the above issues or other relevant topics would be appreciated.
