Engine belly pan clips
Telco
2003 Lincoln LS V8
Does anyone know what clips are used to hold the belly pan under the front of the engine are? When I did my cooling system I was in a hurry to get the car back on the road. The pins were kinda cracked when I pulled them out, and now I can't find what I did with the surviving pins. I'm hoping someone has part numbers, or Help! numbers for the pins so I can go to the parts store and pick them up. Worse comes to worse I can see if the dealer has them, or just hunt something that will work but I'd like the correct pieces if possible. It would just be a matter of convenience if someone here knows what they are. Thanks.
They should be a generic clip that you can find in the Help! section. As long as it is the correct size for the screw it should work just fine.
