Passenger Window
PNWLINCOLN
PNW, WA
Hey guys just realized today that the passenger side window is not rolling up all the way, what should i look for to remedy this problem, any help is greatly appreciated.
Thanks!
Thanks for the info I guess I'll be pulling the door panel apart after work to see if indeed these are bad.
Hopefully you can replace those "Guide Clips" But, if you find other damaged plastic parts -or- a problem with the Motor itself -or- snapped the cable, etc...? ...You could purchase a full replacement "window regulator" and framing from Amazon. Just figure out what pieces are damaged. But, just as Jiovanni12 said, it's more than likely the "Guides".
I did both sides (drivers & passengers). Pretty easy once you do one. *Hint... Just don't foget to "re-plug" the electrical harness to the motor. I forgot both times !!! pretty funny. had to remove the whole thing again.
====>> If someone needs a "detailed" picture of the window regulator, parts and framing assembly ???
I still have my old one, that I could take pics of for anyone who needs it, for whatever. If so, Reply.
Thanks for the extra info, if you have pics you can upload that would be great!
This is what the Window Regulator Assembly looks like and what it costs for Regulator and motor.
Here are today's Amazon prices...Make sure you Verify the correct Part# that fits your specific model/year. I've never ordered those "white Plastic pieces" (Jiovanni12 linked to. Someone may
need to verify, that these will re-attach to the Window-Channel.
$73.00 (Driver's Side) Front Window Regulator w/ Motor - h**p://amazon.com/dp/B000Q0NOTS/
$68.00 (Passenger's Side) Front Window Regulator w/ Motor @ h**p://amazon.com/gp/product/B000Q0PEQE/
Well its my B-day tomorrow and I took the time off from work so I'll be digging into this to determine what exactly the issue is, thanks for the pics im sure they will prove to be very useful.
Tore into door panel today and the white plastic clips are indeed bad, followed link provided and I'm good to go thank you ebay, now hurry up and wait!
need some more info please!
So I tore into my door and it was indeed the plastic clips. I have the new ones and have attached the back one to the wire as needed...but have 2 questions before I try the next steps:
1) The two wire ends are attached to the front broken clip and the tension is very tight. How do I relieve the tension to get the wire ends out and onto the new clip? I'm afraid if I just pull one end out with the tension where it is that I'll never be able to pull things tight enough to get the 2nd wire end into the new clip. What's the secret here?
2) When I reattach to the door frame, where do I need to set the clips and window position? Does it matter? Up position, down position, etc? Want it to be set to go all the way up and down.
Thanks in advance for your help guys!
You may have to re index of the motor auto up/down after repair: Press and hold the switch in the auto down position until all the way down. Then press and hold the switch in the auto up position. Continue to hold the switch until five seconds after the window is all the way closed. Now the window completely rolls up and down correctly.
I have had to do this even after replacing battery.
