Age old question... stand alone trans cooler, or in sequence?
Stangman
Project car a.d.d.
Sardinia, OH
Ok here's my scenario. Trans has been rebuilt in my car. It overheated. Cause was insufficient flow thru stock radiator trans cooler. Barely anything. So, I can buy a new radiator for a little over a hundred, or spend just a few bucks more and get a stand alone trans cooler.
Which route should I go? Looking to get this within the next month to get the car finished up.
I would *like* to hold out until the all aluminum radiators start showing up on ebay again, and do that. So that sorta deters me from getting a new rad. I am leaning towards a standalone.
But isn't there some sort of cooler bypass that is needed? But they always fail? I remember reading something along those lines.
Also, what's the best large cooler for the money? And, once a cooler that large is chosen, does it matter on the stacked plate design since its larger?
Sorry to go on and on.
I use the same cooler as ROTM and it's in the same location. The only thing I might add is that if you are not running an aggressive stall (3500+), the 40,000 may be a bit too much cooling for your needs.
I would look at either the B&M or the Hayden Plate coolers.
http://www.makcotransmissionparts.com/OC-1677.html
How you mount them determines the model. I chose the one above. You can see my cooler mounted behind my Gen1 Spider Valve relays. Also plumbed in line after the radiator (cool weather friendly).
I actually just had a 3500 stall installed. I will take a look at those 2 links when I get more time today.
My current secondary cooler is in the same spot as yours Roadboss.
A t-stat can always prevent overcooling if there is a concern for that.
my cooler is also mounted in the same general location as ROTM. its about half the size, but i am running a stock trans still.
With your conv I would recommend the one in my write up.
Took a look at your thread Frank, that's exactly what I'm looking for. Thanks for the link... looking it up on ebay now....
I wouldn't even recommend getting the one with the bypass valve unless you are driving it in the winter. The cooler is THAT efficient.
