04_Lincoln_LS
Hello!
I have been a long time lurker on this forum and now I have decided to join after a long battle with the LS.
Name is Jose and I am from Houston, TX.
Not a great way to introduce my self with a few question for the LS GURUS already LOL
Yes, I have used the search tool plenty of times but this time I cant really find a solution for the problem I am having. (Maybe)
2004 Lincoln LS 3.9L with about 118K miles on her.
The radiator fan is working way too much (Loud) to maintain running temp on the car.
I have replaced the T shape hose (#1) OEM
Replaced Thermostat housing and Thermostat (#3) Aftermarket (Duralast)
Replaced the hose assembly OEM
Replaced the water neck assembly OEM
I also did a coolant bleed from the link you guys have provided in past threads
Here are a few details of what I have seen when the car is running.
1. Car does not overheat but FAN RUNS LOUD
2. T-Shape Hose (#1) gets hotter than normal (I think) (After I shut down the car I feel the hose and it feels like theres is some bubbling inside going on, Vibration type of feel)
3. Hose (#2) that connects to the degas bottle is hotter than normal (I think)
4. There appears to be condensation ( air bubbles ) in the degas bottle
-----Degas Bottle has some cracks but are not serious(I think)--------
-----Also when opening Degas Bottle (There appears to not be much pressure being released when opened---------
5. When vehicle is idling or rev'ed up to 2k-3k rpm's I noticed there was some bubbling effect in the degas bottle (too much movement inside) ( Also the bottle is very hot)
Hopefully I have provided you guys with enough info to help diagnose this problem.
I would GREATLY APPRECIATE any help!!!
Let me know if you guys need any additional info on the car.
THANKS!!!
-Jose
THANKS!!!
-Jose
