I'm not sure if these issues are related to the same root cause but may be. For a very long time, I have had the ABS activate on every stop regardless of pavement conditions. Seems its one or two light pulsations and that's it. This never sets a code.
However, I do periodically get codes C1233 and C1234 to set together. It's never one or the other, always both. Conditions that trigger these codes include initial warm up under extreme cold conditions. And, very agressive acceleration. I can duplicate the light on and code setting every time when accelerating hard.
Both front hubs were replaced with Timken brand hubs for growling about a year ago and I know for sure the every stop activation was also occuring prior. Don't recall the codes setting though.
The only other thing I notice is that the pedal seems to fade to a certain point when stopped and manually pumping the brakes doesn't firm it up; the pedal will still fade the same as without pumping the brakes.
Anybody seen this or have ideas????
