journeyman291
Ok I am at my wits end. My 97 Mark V111 (147k)is warping front rotors at a unbelievable rate. In the last 2 years I had brakes replaced by a local garage twice within 5 thousand miles each time with new rotors from NAPA (their best Chinese rotors available, although am using cheap"oem" pads) Now for the third time I personally replaced rotors again, replaced calipers,flushed brake fluid and had car in shop to check run-out. Now it has been less than 300miles and I can start to feel wheel shimmy and shutter in brake pedal when braking on a down hill. Still using same pads as they are not cracked or worn hardly at all. Did the post rotor break-in ceremony too.
