Aviation
When going over bumps id hear a clunk and the steering feels loose. Now when the car dips i hear kind of a squeak, and the same thing when I turn the wheel left or right. I can really hear it while sitting in place and turning the wheel. Sounds like the driver side.
Trying to avoid replacing both for now if possible...could it just be the lower? Or does the upper go bad at the same time?
I am going to check when I get access to a jack and pull the wheel off so I can take a look at the lower, but how do you know if the upper is bad?
Ball Joint Squeak - YouTube
This is what it sounds like when I turn the wheel.
