doubledeala
Working on my uncle's LS. Not sure of the history on this car but it's been sitting dead for about 5 months. He just got back in town and wanted to take use his car again.
It cranks very slowly, probably 2 slow 'whirs' and quits.
At first, I thought it was the battery so I tried to jump start it. Didn't work. Had battery tested and replaced as a result of, figured it needed a new battery anyways.
Pulled starter out had it tested, all good. Put it back in, slow crank.
Checked voltage drops and honestly, I was in a hurry and it's freezing out here so I might have missed something or did something wrong.
The battery is wayyy too far to connect my multimeter from the battery terminal to the starter so I connected a jumper cable to the negative terminal and connected my multimeter leads from the cable to the starter body and then the cable to battery positive. Repeated for positive terminal on battery to starter positive post.
While cranking - From neg terminal to starter body, very low, like 2 mv. Neg terminal to battery positive...7.XX V - which is telling me some power is going through the multimeter and not the starter.
Cable resistance issue? Maybe. So I took jumper cables and connected neg battery terminal to starter body, battery positive to starter positive post.
There should be a straight line to the starter so any resistance in the previous cable would be negated by the jumper cables right? They're pretty hefty jumper cables so I'm sure it can carry the current.
So, I check the oil, bone dry. I'm thinking the engine is locked so I pour in new oil and now I'm at a standstill.
Starter can't rotate with locked engine so it's causing high resistance and current decides to flow through the multimeter -- my theory.
It's an auto so I can't just push the car to rotate the crankshaft. It's a very tight fit in the engine bay to get to the crank pulley.
My cousin is in the process of removing the radiator and intake manifold to pour some diesel down the spark plug holes and turn the crankshaft pulley by hand. Cross fingers...
Any suggestions thoughts or commens?
