nghtshd88
I went to get an oil change and they mentioned they topped off my fluids a little as well as mentioning an oil leak I knew I had. When I got home I checked it all and a good pint of orangey fluid was right under my PS rack right behind the oil pan as well as right beneath the passenger headlight, those two lines that go into the bottom of the passenger side of the radiator also had a minor leak.
This is orange and it doesnt smell like trans fluid at all but has a faint smell of coolant. What are the two lines going into the bottom of the radiator? Both leaks came at the same time with the mid one being pretty bad.
I just recently had a trans flush and my coolant recently decreased a little rapidly.
