perpetualchange
Greetings. I drive a 2004 V6 Lincoln LS, and recently have had problems with the engine light coming on, as well as the car “shaking” when idle for a few minutes after start-up (my commute is about 30-60 minutes depending on traffic and the “shaking” would stop after 5 or so). I have never had these issues before and I'm hoping that this isn't the beginning of what seems to be a pretty common problem.
After an autozone reading I learned that the engine light was on due to a Cylinder 1 misfire. I changed the coil and spark plug on the first day. After the work was done, the car continued to shake with the check engine light remaining lit, until reset from the battery. After that, the car stopped the shaking and the check engine light did not turn on. The issue has not come up again for the last couple of days, thankfully.
My question is, although everything seems OK for now, I have researched around and noticed that this problem (coils and plugs) is a pretty common one. I know that I’m probably going to have to change all the coils and plugs soon, which I’m holding off on because coils cost at least $50 a pop and getting the manifold off so I can change coils 3 and 2 is going to be a pain in the rump (I was able to do 1 without taking off the manifold, amazingly).
What’s everyone’s experience with these type of Lincoln misfires? How often do you need to change coils, and how much do you expect to pay when you do?
Also, why did my check engine light remain on until reset? I also just changed rear lights after one bulb went out, and the vehicle continues to give me the “lamp out” message even though I know for a fact that all my lights (including brake lights) are good.
Thanks
Thanks
