Hey guys, this is my first post on this forum and I am looking for some tech and diagnostic advice for my '02 LS v6 3.0
I got the car a few years ago with around 45k miles and today it has 68k, since buying it I have changed out one coil and an alternator in response to a misfire on that cylinder (dont remember which one) and a electrical issues and have been pretty much ok since.
I say pretty much since the thing is that since the first day I got it the car would always idle pretty up there - the worst being 900-1000 rpm but usually around 800-900, and when engaging the transmission into either Drive or Reverse it kinda jerks (more like a jarring lurch) into it, but once engaged it seems that it works as it is supposed to.
Oil changes have been done every 3k regularly and since I got it the plugs have never been changed - I have no info from the previous owner.
A few days ago when it was raining and I went to start the car in the morning it felt like it was misfiring but no check engine light and when I went ahead and put the car in reverse it engaged and immediately died. Restarted, put into drive and was sort of fine for about 10 minutes then started (what felt like) misfiring and died - again no CEL. Restarted and took it back home slowly, the next day it was perfectly fine and has been since.
I am handy with tools and am ready to pull off the manifold and change out the plugs etc. but in relation to my symptoms is there anything in particular I should look out for and/or change out while I am in there? Also, what are the best recommended replacement plugs?
