Rear seat removal
For the bottom:
There are 2 "hooks" on the front portion underneath the seat bottom. One behind each front seat. Push back and pull up on each side. Some require a little muscle.
Once the bottom is out you'll see 2 bolts, 1 on each bottom corner. The bigger brass looking nuts are for the seatbelts. Once the 2 bolts are removed pull it upwards and out.
The bottom comes out first. Just push in on the left and right side and lift up and pull out. 13mm bolts hold the seat back in place.
Green arrows points to where each nut is (I think there 3/4) and the hooks are in the green circle. Like they all said push towards the trunk and lift.
What are you doing with the seat out? Or is it top secret
The upper cussions bolts are 13mm... and those circles are Red -_-
