Cobra fuel rails(:
Htrlman1
Spring
Just ordered and got one hell of a deal on a 97 cobra fuel rail with 24lb injectors and 2 fuel hoses that look like extensions. Now all I have to do is find a good clean manifold with some imrc's. Any advice on this project
I saw those for sale. I noticed the 2 extentions also. You will run into intakes for sale all the time. Patience grasshopper. What year is your car?
It's a 98 base, and I did find one on eBay and it came with upper lower imrc's and gaskets for like $330
You don't need to change the IMRC's, the ones on your car will work fine with a '96-'98 Cobra intake. They're the same as what was installed on a '98 Cobra.
Thanks,
So all I need is upper and lower manifold. Maybe injectors, I don't remember if they are the same as the mark
Like what? I have fuel rails ordered but I can't think of anything else. I think there is a bracket for throttle linkage that I need. Can't remember but I think DLF makes it lol
Have you read all the gen2 cobra installs? There are many out there. There are always things that snag you. I got freaking everything to do swap. I have a gen 1 thou.
No ill start searching, gen 1's are always better anyways
No, I don't make throttle brackets.... :rolleyes:
Here's a link to my install, there are quite a few little bits that you'll need to round up.
http://www.lincolnsofdistinction.org/vbulletin/showthread.php?t=32824
Say What?! :eek: :p
