painting chrome parts
lking
Canada
i want to paint both front and rear chrome parts (not sure what they are called) what options do i have? I was thinking i could just buy some spray paint but will it last? should i sand off the chrome first?
how can i pull these parts off? do i have to take off the bumpers?
Not sure how the trim pieces come off, but you will want to scuff them up and use primer before painting.
Be sure to scuff ALL the chrome, and use enough self etching primer, and enough clear coat.
I learned the hard way lol. My grille is ugly right now lol
You could buy the one I have for sale and start over lol
Speaking of Grilles, what would you take on that mclaren Manoli ?
Let me know when your rent is due ?
j/k
does anyone how i can take them off? i tried pulling one off i heard a noise something fell into the bumper but i couldnt get it out now the end is lose
I'm pretty sure you have to take the bumper off and bend the clips back that are holding them on.
Rough it up, spray it with self-etching primer, then paint it.
1.sand off the chrome using sand paper
what grit?
2.spray it with self-etching primer
does this come in a spray can? never-mind stupid question
3.paint it
with what? spray paint can? or home paint like what you use for walls
this is my first time doing something like this so i have no idea
what kind of black paint metallic black?
Make sure you use adhesion promoter too. You can get all the supplies at your local parts store for around $35.
You sir are correct.
when do i use the adhesion promoter before prime and paint after sanding ?
Multiply that by 3x in Canada.
lking: stop being a baby, google is your friend.
what grit?
3.paint it
Steps (just what I did)
1. Sand (400,600,800 grit)
2. Clean
3. Adhesion promoter (2-3 coats)
4. Primer (3-4 coats)
5. Wet sand (1000 grit)
6. Paint (3-6 coats, I use duplicolor colormatch from the parts store)
7. Wet sand again (1500 grit)
8. Clear (3-6 coats)
you'd want to sand the chrome enough to make it 'dull', don't worry about sanding the chrome right off.
pay close attention to the sharp edges, besides the shiny flat areas this will likely be where it peels first if not done properly.
clean it with IPA (rubbing alcohol, not pale ale)
make sure primer, paint, and clear coat types of paint are compatible.
Some types don't need to dry between coats. follow instructions on label. resist doing a single thick coat, do multiple thin coats (again most of this stuff is on the label)
good luck and post pics when done
Thank you
i wont get started right away but i will get it done eventually and i will post pictures for sure when i'm done
before
before
before
after
sanded with 400,600,800 sand paper now ready to addhesion promoter,prime,paint,and clear coat
cannot find adhesion promoter what if i skip this step?
The paint will probably flake off eventually. Have you tried Cdn Tire and NAPA? C'mon you live in the GTA, phone around.
ok got it all from the local Canadian tire except the paint they didnt have anymore black ford left could i use the black they have for Honda or Chrysler?
whats the black OEM paint called on these cars they had blackburn black misca black and metallic black
i returned the bottle on the far left side Acrylic Enamel it wasn't an actual clear coat just a high glass and got actual clear coat
