CTX-SLPR
Howdy,
I tried searching these questions but no definative answers.
1. Strut mounts, are they needed when replacing the shocks? From my work on my FWD Buick, I replaced the fronts because they had McPherson bearings in them. Since the LS doesn't have a McPherson front suspension, are new mounts a good idea while I'm in there?
2. What is the difference between the Motorcraft "Service Replacement Kit" shocks and the regular shocks listed by RockAuto?
3. Is there a good definative aftermarket replacement sway bar bushing for the front of the Gen 2's? I don't want to spend the money on a factory piece of metal when the bushings are the only thing a junkyard setup would need.
4. Rear sway bar bushings from Ford only?
(Note: going from a base model suspension to a sports suspension, hense the need for bushings for sway bars)
Thanks,
Thanks,
