Radiator Cap
Tasca, FordPartsGiant, you local dealer, or a few hundred other places. Get the Ford OEM one, not the Doorman one.
There's an engine fill cap, and the degas bottle cap. Be sure you get whichever of those two that you need.
Does air get introduced into the system by removing the engine fill cap?
Its the degas bottle cap and I'm considering replacing the bottle as well. I have small coolant leak and the mechanic told me its the cap
Yes, I would replace the degas bottle and the cap. It's much more likely that the leak is from the bottle than the cap.
Joe can you give me the part number or link to the ford oem bottle, all I can find is the dorman model
:) Hey my name's Joe as well so...
Tank Assy - Radiator Overflow: 4Z-8A080-AA
Cap Assy - Radiator: 3Z-8101-B
Run ya roughly $150 from FordPartsGiant.com
Just updated...The radiator cap did not fix the problem as expected and the radiator fan still comes on after about 20 minutes of street driving. Also I still notice some coolant on the ground when I turn the car off. I turned my A/C on Max heat and the radiator fan would slowly turn off so I'm guessing that would rule out the Fan Relay needing a replacement which Wheel Works suggested. Currently waiting on my degas bottle replacement to arrive to change that out, hopefully it works.
... I'm guessing that would rule out the Fan Relay needing a replacement which Wheel Works suggested. ...
That would be a neat trick. There is no fan relay on the gen II LS.
