Volvo Wheels
hinzy
Central
Do you know if these Volvo wheels will fit an LS?
Anyone on here use these?
Item number: 271046699066
Rim Width: 7.5
Rim Diameter: 17
Offset: 49
Bolt Pattern: 5x108
I'm looking for winter wheels and found a set of these close to me pretty cheap
Thanks
From what I've searched it seems as if they would, I just want to be 100% before I go pick them up.
Yes those are the same exact dimensions for stock LS wheels but why only 17s?
I thought stock LS wheels were 60mm offset :confused:
Basically that was the only thing I was questioning.....
I'm not too picky on the snow setup, I'll take what I can find that's cheap and looks decent.
Basically straight swap over, beside the center bore being a tad bigger on the volvos.
Ls = 63.4
Most volvo's = 65.1
xc90's (might be just the newer ones, 06+ or maybe -8+) = 67.1
I dont remember, but I think a few of the older volvo wheels are the same bore as the ls, and maybe also a little smaller.
Got your message. Yes those should fit just fine. With a 49mm offset they will stick out a bit more than stock(60mm), but in this case its a good thing.
I would recommend hudcentric rings tho to prevent any vibrations since the center bore will likely differ as Alex mentioned.
