HELP! Bleeding power steering pump
kitbuf
coastal
I have searched and searched and can't seem to find the answer. I have replaced the pressure switch in the power steering pump cause it started leaking. Of course, when I replaced that I lost the fluid out of the reservior. I have filled the resorvior back up and need to know how to bleed the system because it is now whining when I start it because it apparently has air in the system.
Start the car and turn the wheel (almost) lock-to-lock. When there are no more bubbles in the reservoir the system is bled.
