Yes, I know this is a repost. But as many people have tried to do this, I believe it deserved its own post.
Switch-Back LED bulbs are signal/park combo bulbs designed to replace the factory incandescent bulbs. When the park lights are on, switchback bulbs light up white. When the signals (or hazards) flash, the bulbs flash amber, and "switch back" to white when they stop flashing.
Well, I gave up on trying to figure out how Ford pulled off the circuit for the front park and signals. I instead turned my attention on how to make it work with the switchbacks.
Here's the necessary circuit to make it work.
You will have to do this for each side, so it means a total of 4 relays to do the front two lights.
*** Note: This is for Gen II. I have no clue if this works on Gen I ***
This is what you should end up with after doing the relay circuit.
This is NOT the exact socket from the LS, I'm just using it for reference. Two contacts on one end should switch on positive, and two contacts on the other end should be constant ground.
If you do this, and the white flashes or the amber is on solid, the wires going into the socket are reversed. With a "Type 2" switchback (most common), the white should be solid when park lights are on. When the signal is turned on, the white turns off and the amber flashes solo. (With a type 1 switchback, the white will remain on while the amber flashes when connected properly)
Switchback Install on '03 Lincoln LS - YouTube
Switchbacks on '03 Lincoln LS - YouTube
