04_Sport_LS
Hello,
New here. Acquired my 04 LS in January, and have been lurking for a while. Lots of good information here, including customization/upgrades. Been reading on different rotor/pad combinations that people are using, and decided to join because I have some questions, and have found some different parts that no one has discussed, and it may be of some interest to members.
Recently, during a front hub change, i noticed that my front rotors should be changed. Pads were in good shape, (obvoiusly changed at some time), but the rotors had a lip on the edge and the pad contact surface was countersunk in relation to the outer circumference. I guarantee they are below minimum spec, (or would be after turning). Seems typical to the last decade of Ford vehicles with higher mileage, that still have factory rotors on them.
I have been scouring this site, and the web, (in an OCD manner), for ideas on replacement pads and rotors. I am looking for parts longevity, along with a performance upgrade. I believe in, (and have had excellent experience), with turning, or replacing rotors, with every pad change. In fact, I recommend it.
Beyond the standard local parts store offerings, (of which Bosch and Napa Premium are the only ones I would consider), I have been looking at standard blanks, drilled, slotted, drilled/slotted, cryo, dimpled, diamond cut/slotted, high carbon, alloy, and different combinations of all of the aforementioned processes. I am aware of Centric, (and all of their different offerings), Brembo, ATE, Baer, EBC, Carbon Z, Raybestos, Stillen, Textar, Wildwood, Zimmerman, and different manufacturer's BBK offerings.
There are some that I have forgotten to mention in the "overload" of my research. Not all of these companies make rotors for the LS, and some of the ones that do, are outrageously expensive. While my driving can be agressive, I do not "track" my LS, so ultimate performance is not necessary.
I am a staunch supporter of "Made In USA" products, when possible, and China and Mexico are 5 letter cuss words in my book, when it comes to manufacturing, (no offense meant to any nationality). This country is in the toilet because manufacturing has went elsewhere, (don't mean to flame here, don't want a war). So that leaves very few offerings that fit my bill. I will consider European manufacturers. I am not afraid to spend $100+ per corner, without going to extremes. I do not believe in the long term performance and quality of $20 rotors, or most of the cheap online, or Ebay drilled/slotted variants. If it's not sold by a reputable e-tailer, (with manufacturer references), or maunufacturer direct, I will not buy from the website. That, to me, leaves the following choices... which as far as my searches on this site have revealed... have not been discussed on this site.
frozenrotors.com - I have talked to them. They use Zimmerman castings, which have mixed reviews, depending on the vehicle and driver. From my understanding, (not fact), they are partnered with Centric, and cryo Centrics offerings, but also operate independently. They offer blanks, slotted, and drilled/slotted. Some are zinc plated, and some are e-coated at the hat. I unfortunately do not have their correspondence with me anymore, but it was encouraging.
ssbrakes.com - Big Bite Rotors seem to be very well maunufactured, and they have been late in the drilled/slotted entry, to make sure they have addressed the quality issues with these types of rotors. I have talked to them to, and they do defend there product against common cheap d/s rotors, and do have some interesting information on their website...
I checked their site, and the left rear rotor is still currently listed under Jaguar/Thunderbird. Part #23549AA3L
sp-performance.com - These guys are a little more obscure, and it seems e-tailers are limited to Ebay. I have yet to contact them to discuss the origins of their products, and purchasing options, and some of the typos on their website make me wonder if it isn't broken English, but from what I can tell, it is an American company, and they have some very interesting concepts for their rotors. Especially the way they chamfer/drill the holes.
The fouth consideration was Centeic Aero Rotors, but after corresponding with the company, they are only available in a BBK. Too bad... They are 100% USA made.
It appears, (not fact), that a foundry in Okland California still makes rotors for Centric, and a couple of other manufacturers that I can't currently remember.
www.ate-na.com/ - They make an interesting slotted rotor, that is not out of the question for me.
I have read the pros and cons of drilled/slotted rotors, but the aforementioned companies seem to have addressed the cons. I don't want to get into the drilled/slotted vs. blanks debate.
I am thinking of using Akebono or EBC Redstuff pads, if I decide to use drilled/slotted rotors, because turning these types of rotors is very questionable, and these appear to be gentler pads. If I go with cryo blanks, then they are "turnable" and more agressive pads can be used. I have done countless brake jobs, and even some "mods", but have never dealt with drilled/slotted rotors... So now to my questions...
How bad are the slotted, drilled/slotted rotors for noise??? My car is a daily driver, and I don't want to deal with a lot of noise, but I do want improved performance.
Has anyone had issues with the zinc coating, or other plating, with any specific type/brand of brake pad???
Had anyone run across an extremely bad rotor/pad combo that should be avoided???
Any other gentle pads, that are best with drilled/slotted rotors???
Any best pads that work best with cryo rotors???
I would prefer any pads I buy, to be "low dust". I hate cleaning rims.
PLEASE KEEP ANY AND ALL COMMENTS EXPLICIT TO THE LS. Thanks in advance, and sorry about the extreeeeeeeemly long first post. I just wanted to make sure I explained myself fully to remove any questions or confusion. I also hope I have added some options for people interested in upgrading the brakes on their LS. I will mention that I am in no way affiliated with any aformentioned company, nor am I in the parts selling business.
---Mike---
Hello Mike,
Thank you for contacting SSBC with your braking needs. Our rotors, just like everyone elses are cast in China. While some companies claim to have "American Made" rotors, the sad fact is that there hasn't been an american made rotor since the early 80's. Companies can claim to have american made rotors if 51% of the manufacturing that goes into the rotor is done in the US. While in fact that the casting is from China still. Even though all rotors are cast in China, there are still different levels of quality offered from China. We purchase the highest quality castings available and finish the machining in Canada in order to insure the highest quality piece to put our name on. Our rotors carry a one year warranty against defect. All cross-drilling is place in the cooling valleys as to not alter the structural integrity of the rotor and all holes are chamfered to eliminate cracking.
I have addressed the left rear caliper not being offered on our website for your Lincoln. Thank you for bringing it to my attention. Please let me know if there is anything else that I can do for you or if you would like to place the order.
Sincerely,
Dan Classer
SSBC Performance Brake Systems
Mike,
Thank you for contacting us about our AeroRotor program. While we are planning to offer these parts for more applications, the Lincoln LS is not one of the vehicles we plan to support. For a stock size rotor upgrade we do offer PowerSlot and SportStop parts as well as braided lines and pads for the stock calipers. We also offer a complete big brake kit for the front and rear axles.
Let us know if you have any questions.
Erik Steinkamp
---Mike---
