Cant Find Ignition fuse?
HoustonSwangerLs
Houston
Hi i have an 05 lincoln ls an am looking for the ignition fuse. i want to conncet my subs to my stock stero i have the line converter. an everything else conectected correctly. i just need to find out wear to connect my remote wire.. any help or sugestions
Tap into a speaker wire. You don't want to touch the ignition system on the LS unless you want really bad results.
This is where my remote is running from. My LOC didn't have a remote hookup so this is the first thing we found when putting 'er in.
Blue wire (my remote wire) connected to green wire connecting relay 7 and diode 2. Reference the inside of the cover for their position if the pic below doesn't help. Don't know if this is the fuel pump relay but that's where my remote is coming from. Turns on when the keys turned on, turns off when the keys turned off. Won't kill the battery listening to tunes when the car's not running.
PS: I had to search for this post, it's easy to google search knowing exactly the right words to punch in there.
can you
[ Can you send me sum better pics showing where you have your remote wire conected i cant really tell with the one that is showing all the wires very confusing please help]
