2002 LS 63K miles. This all started when one day the car didn't start. We had it towed to a Meineke where the tech said your alternator is bad bcuz battery was not holding a charge. He replaced alternator ($420+) and we bought a Champion 65W battery which he installed.
My mom got the car back and the needles are going all over the place
The indicator lights come on and then go off.
The message window says check charging system. I look at the battery and there is droplets of water around refill caps.
The Tech blames the problem on the previous owner and implied that the car must have been in an accident and has mismatched modules that have to be flashed.. I don't believe this, previous owner told me car was never hit. I can tell, CarFax is clean, seams and body lines are even, rubber seals good no overspray, everything is as it should be.
I suspect the remanufactured Alternator is the culprit because the car never did this before.
I've seen a few threads similar to this but not quite and I was hoping someone could speak from experience on this particular issue. The guy flat out wants to point the finger everywhere else but his rebuilt alternator.
Anybody else have these symptoms where the lights on the dash go on and off the speedo goes from 0 to 160 tach goes from 0 to 7 and the A/C goes on and off?? It all seems to happen when you accelerate and only after the car has been running for a few minutes
Thanks all!
Corey
Thanks all!
Corey
