topher5150
When I'm at a light or something with the A/C on the engine has a bit of a stumble, no CEL.
Mine clunks every once and a while when first turned on for the day.
We need a dedicated a/c thread
Mine is more consistent. Come to think of it it's been some years since I changed the plugs and fuel filter.
That's not a bad idea. I think mine needs a new clutch. The metal ring behind the triangular thingy (okay, I don't know the actual "name" of the part) is loose and rattling around. It doesn't affect the operation of the a/c when it is turned on, but it causes a 'chriping' when the engine is running and a/c is off. Sounds like a tensioner pulley. And mine feels like it loses about 20hp when the a/c kicks on. And I've been running the a/c a lot lately due to the 100+ degree heat and my average mpg has gone from 20.9 to 20.2 in less than a weekBut that's probably normal. Anyhoo, dedicated a/c thread would be nice
Might be a good idea to do so...
20 avg mpg. I'm only getting 17.5-18.5 city/highway
I just went through this on my car. The thing that is rattling arround is the clutch hub. There are 3 rubber bushings that have popped out on your hub. Your clutch still works, but not as well. Plus, as a result I am willing to bet your pulley bearing is bad. Both parts are easily inspected and replaced. Take the belt off the pulley and spin the pulley. The bearings should not make any noise. The hub is removed by taking out the bolt in the middle and just pulling it off. There is a small spacer in the hub that sets the gap between the hub face and the pulley. Don't loose it. The pulley just pulls off after removing the retaining clip. The pulley fits tight arround the clutch actuator and center chaft so it might need slight persuasion or a puller. Mine just pulled off. I replaced both parts with the compressor on the car and without discharging the system. The down side is the pulley and clutch hub together are close to the cost of a new compressor per Rockauto pricing so it may be better to just replace the whole compressor. I happened to have a spare low mileage compressor that I swapped the parts off of. After doing this the car and the AC seems to be working better. Plus the anoying chirping noise from the pulley bearing is gone. I have a thread on LOD in the AC section with pctures.
Oh, that clutch hub rattling arround is not good. Your compressor is working harder to engage and will stay engaged for shorter periods. It is just leading the compressor to an early grave.
That happened to my Grand Marquis. Clutch started rattling something feirce on a trip down south. It siezed up about a month later costing me 7xx bucks.
If that ever happens to the mark it'll be recieving a bypass pully.
OMG I wish I had customers like you.. $700 for a compressor swap and recharge is INSANE
