Lincolnlsman2
2000 lincoln Ls tranny will go in any gear but will not move unless put slap, put in slap it will turn the tires over just fine, put in reverse high rpm will slowly move back any help would be greatly appreciated thanks
prolly one of the bands is toast. when you put it in sst, it skips to 2nd right? it uses a different clutch pack then? and that's why it can then move.
Gen I skips to 2nd in auto as well.
that's interesting. didn't know that.
The exception is if you floor it (or nearly floor it), then it will start in 1st.
Nope. In D5 and D4 the trans starts in 1st gear. The 2nd gear start in SST was required to prevent the gas-guzzler tax from kicking-in.
