Searched about windows falling off track, but none that seem to talk about my situation.
For the last few months the driver side window had this problem where you could lower it no problem, but when you went to raise it the thing would get stuck about halfway up and pop forward a little bit. You had to let off the switch, pop it back into position, and then it would go up fine. Repeat the process.
Tonight however it finally stopped working. I popped it back into position like normal, pressed the switch to close it and it got to within a 1/4 inch of being closed and suddenly stopped moving, but the motor was still going. Passenger side works fine. When I press the button, the motor makes a continuous noise like it's trying to pull on the window but it's just catching air.
Before I pull the panel off I wanted to ask if anyone knew more specifically what the problem could be. The window stays up by itself, didn't fall into the door or anything. If I get on both sides of the window with each hand and exert a lot of force up or down while tapping the button a few times I can make it move, but the motor still isn't catching anything. Right now I just forced it closed using the above method.
