i think you problem with the car has something to do either with the motor or the dohickey that rest between the airbag and horn button and the up right part of the drivers seat.
Clockspring
..... any other info? what have you checked out so far. Right now I can tell you it's something between the front and back bumper.. perhaps between the steering wheel and seat
The following possibilities based on almost no info:
1. Bad PCV plumbing.
2. Bad MAF.
3. Bad gas / No gas.
4. Bad coils.
5. Bad IAC.
6. Bad fuel pump / clogged fuel filter.
7. Clogged cats.
8. ?????
How about more info? How does it idle? Does it have problems when you are pressing the gas pedal? Is it okay in park/neutral? Is the check engine light on? If not, is it burned out? What octane gasoline do you use?
Don't be driving it much now other than to take it to the dealer and have them check it. Suspect: COP problem (Coil Over Plug/Coil On Plug)
If they need to replace them, always have each replaced with the spark plug at the same time.
It's a very common problem, just part of standard maintenance...
i replaced the fuel pump not to long ago i use chevron supreme
is fuel filter cloging common? my dad told me to take it to the shop and replace it
How many miles? most likely not the fuel filter. If it sputters going up a hill, it is likely low octane gas, only use 91+ in the V6, I know, I have a 01V6. If it rough idles, then PCV valve needs replacing. Follow JOEGR, he knows his stuff.![]()
Definitely sounds to me like multiple failing coils. Is the CEL on? If the CEL is flashing DON'T DRIVE THE CAR!!!!!!! You will cause more expensive damage!
$150 to change the fuel filter? Is the filter made of gold? Sounds like a rip-off!
yeah, the filter is like 10 bucks and its took me all of ~15 minutes to change it I am sure the v-6 has the same set up on gen ones
will you replace my muffler bearings too?
