Suspension Rattle Frustration
Man I need to go start snatching air springs off JY Marks
Ford also calls them Springs. At least thats what my Ford receipts says.
They are refered to as struts in the Ford manual I know as well. So basically even Ford doesnt know what they are ;)
Ford knows what they are:
Also:
From a Ford service manual. I've personally never seen any literature from Ford that calls them "struts". I think the engineers at Ford know the difference between a strut suspension and an SLA suspension. But I could be wrong. One never knows...
You'd also think they knew better than to use plastic for an intake, plus combining a coolant crossover into the same piece ...but refference a mid 90s Gran Marq and you'll see otherwise
Oh I know! My mom's '97 Cougar 30th Anniversary Edition's plastic crossover tube cracked while we were on the 220 bypass going 70+mph. That wasn't fun. Had to have it towed to the stealership to get a new intake. It was under warranty, thank goodness. Thankfully, there was no damage to the engine. That was over 10 years ago and she's still driving the car today. But Ford isn't the only company that uses plastic intakes. It's pretty much standard now on a lot of cars, unfortunately. But the McPherson strut/SLA debate isn't based upon opinion or typographical errors or lack of knowledge (well, maybe that:D). The two suspension types are distinctly different. The Mark VIII has an SLA front suspension, therefore, by definition, it does not use struts.
A peaskey sweak or rattling thunk turning?
I'm justing going to have to ask...When the lower shock asembly bolt and nut through the L.ower C.ontrol A.rm was reasembled what bolt was put back in its place???
This is a common to replace as needed and available Metric Bolt...
is the same bolt before repair still there after repair or is that clunking from this worn/wollowed shank bolt sloping around inthe new LCA bushing?
Is this a new bolt/nut set up or was the old bolt recycled...
Could be anything, Time to strap and tye up a chair on the nose of that Cameltoe...Like in that MadMax movie...
I can't remember exactly...but I think it's either an 18mm or 22mm bolt. You can re-use the bolt and nut when installing new LCA's. If the lower shock mount bushing is worn enough to cause a rattle, you most likely need new LCA's. It's a lot easier to just replace the whole LCA than to press teh bushing out and press a new one in. Plus if that bushing is bad, most likely the other bushings as well as the ball joint are bad too.
