Really need help for saving my 2004 lincoln ls
nickool
san diego
I just bought a lincoln ls 2004 v6 car with 113,000 miles. The engine stalled twice when I stopped quickly at a red light signal. I had to push to P and restart the engine again. The engine light is not on and I did not feel it is the misfire problem (the last owner just changed all the sparks and coils at 100,000 miles). Another thing, each time I change from D to R, I can feel my car a little shake (if I do it slowly, the car don't shake). And sometimes when I push the gas a lot when the signal turns green I heard a big noise which sounds like the gear is not matched. I drove to the lincoln dealer to check the engine problem and they took 3 days and they they can't find any problem about the engine but they found the transmission problem. They performed electronic tranmission diagnosis and said EEC test KOEO pass CONT PASS KOER pass. They told me : the transmission fluid level OK and fluid is varnished. They also do a road test and told me: transmission neutralizes AHEN coming to a stop and shifts erratic also makes whining noise on acceleration from torque converter. They suggest me to change the transmission which will cost 3,700 $. I don't want to pay that much money so I came here to ask for help. This is my first car and I like it. I don't know anything about car but I want to save my first car with a reasonable money.
Many thanks in advance.
Well, there are a few possibilities for the engine stall problem (IAC, PCV plumbing, coils, torque converter, electrical, ...)
Since you already know that your transmission is toast, you should start with that. Since whatever fault it has was allowed to go long enough to varnish the fluid, the whole transmission (and torque converter) needs to be fully rebuilt or replaced.
You will need to bite the bullet and have the trans rebuilt. Witt used to do quality work........
Sometimes thats the price of owning a luxury car. something that has to be factored in when purchasing this kind of vehicle.
although if you search around, you can have it fixed/ replaced for much less than that.
