Brake Rotor Replacement...
Thanks for the reply jd. We have over 50 programs depending on what type of material we are doing.
The machine is computer controlled with the latest and the greatest. Most programs will follow a 1 degree/minute process, both up and down. Some will be .5 degree/min and some even less at .3 degree/min. depending like I said on the type of material and overall weight/density of the parts. Our average total cycle will be 36 hours. We are NOT doing this to try to crank out parts for a quick profit. We got the unit to do our own stuff, mostly cart racing things like blocks and cranks and rotors, etc and I figured there would be a bunch of guys that could also benefit in the Ford/GM automotive community. Our machine has a range of -300F up to 575F. We have 2 internal blowers in the unit to move the air around so the process will be very consistent and even.
Obviously the most expensive part of this process is the nitrogen. Fortunately I buy huge amounts of nitrogen in gaseous form now so i should be able to secure the best pricing also when it comes to the liquid form.
I am pretty excited. We researched this alot before taking the plunge. Especially with Ford's we expect to do a fair amount of business with rotors and pads seeing as how they are notorious for warping. This process will solve that problem.
I'm doing my whole motor along with most of the moving suspension parts.
I'll be posting pics along the a write-up of the process and pricing.
Should be pretty cool. Pardun the pun.
R1 Concept Brake Rotors
These are the same rotors I put on my '97 Mark. I bought them because they were on sale and shipping and everything was right at $140. They will make a little noise when you get almost to a stop under heavy braking (deer) but do make the car stop faster. No problems with the coating. I have Duralast pads from AutoZone on them and the dust is at a minimum. Do not mess around the rear calipers! No vice grips, hammers, channel locks or anything like that. Go to harbor freight and spend the $20 and get a caliper piston spin down kit. It will pay for its self in less frustration. I also works on all calipers including the front dual pistons of the Town Cars. If you get a scar on the side of a piston from trying to push the piston in at an angle then you will have a headache.
Where are you located at. I work for a gas distribution company. If I am not close, I can tell you based on your needs what set up would be best.
If you are using high pressure cylinders, the product is not your highest cost... moving the cylinders (labor) is your highest cost. You are also sending back nearly 30 percent of the product when you replace the cylinder... even if the guage reads empty. You can not withdraw all the product. Your supplier does not want you to know that.
PM and I can give you some info.
T
