dwenz
Ok everyone been reading on here for two days all the threads on overheating. Great site but Still cant find all my questions answers OK were talking about a 2000 v8 LS It just started temp guage goes hot upper radiater hose is hot,lower radiater hose cold.Tried the fill procedure 3 times. Temp guage starts normal,then goes to 9:00 heat comes out of duct work best at 2000 rpm then at idle cools down. Then after 5 min temp guage goes on up to hot. The motor is hot . Motor seems to push out boiling coolant out degass ..but radiater lower hose cold
Yes fans are working on high and low. Thermostat is not gunked up or blocked I checked,also is not sticking I can open it with a push
Also I saw a mist or steam come out of duct work a couple times when messing with heater control at first start up.
I'm thinking water pump due to the fact lower Rad. Hose has no temp in it.
Yes heater blead has steady flow at idle.
Yes filled engine fill to top when engine off..
Please help
Please help
