Rozay_LS
<1 of 12>
Back up for sale again last guy bull ****ted me for a week ....YES The car drives and rides smooth what's listed is what needs to be fixed soon
Location; 66112
Contact: 913-223-4418 call but text is preferred anytime day/night
Year: 2000
Make: Lincoln LS
Model: 4door sedan
Mileage: 137,xxx remain as I do not drive this anymore
Title Status: Clean prior salvage title
Transmission: automatic/Manuel option LS
Price:2000 OR BEST OFFER, will entertain all offers !!!!
Pros-
Excellent letters seats
65% tread on tires ready for winter
Excellent stock rims ( need deep cleaning )
Keyless entry ( needs programmed last one broke )
New spark plugs and ignition coils
Oil change done every 3,000 miles
Custom dual straight pipes ( resonator gone )
New front lower ( right ) and upper ball joints and tie rod
Blacked out tail lights
Low miles only 137,000
6 disc changer
Premium sound
Automatic/Manuel slapstick option
Steering wheel tilts
Big trunk lots of space ETC......
Cons-
Engine needs spark plugs and ignition coils replaced at the same time, I changed them both just not at the same time( May 2013 ) so I'm having a check engine light for a miss fire in cylinder 5,6 an 7 other then that car engine wise is good to go, recently the check engine light has been off for the past month and I start my car for 30min each day . Bad windshield crack ( Front )
No window ( front right )
Front lower ( left ) upper & lower ball joint needs replaced soon
Front fog lights don't work
Bad hail damage all on the car
Carpets just need a good cleaning
Steering wheel volume control an cruise control went out. Due to the ignition coils and spark plugs being bad it caused my catalytic converter to start sounding funny. I have priced brand new NGK spark plugs at auto zone, Advance auto and oreilly auto for $27.69 including tax for all 8 as for the ignition coils I found some OEM ignition coils on eBay for $56.98 for all 8 coils
Performance -
3,950 cc 3.9 liters V 8 engine with 86 mm bore, 85 mm stroke, 10.5 compression ratio, double overhead cam and four valves per cylinder
Premium unleaded fuel
Fuel consumption: EPA urban (mpg): 17 and country/highway (mpg): 23
Fuel economy EPA highway (mpg): 23 and EPA city (mpg): 17
Multi-point injection fuel system
18.3 gallon main premium unleaded fuel tank
Power: 188 kW , 252 HP SAE @ 6,100 rpm; 267 ft lb , 362 Nm @ 4,300 rpm
Handling -
Four-wheel ABS
Four disc brakes including four ventilated discs
Electronic traction control via ABS & engine management
Immobilizer
Spacesaver steel rim internal spare wheel
Wishbone front and rear suspension independent with stabilizer bar and coil springs
I'm asking $2200 or best offer or TRADE priced high for low ballers, I know good and well I'm not getting $2200 so shoot me some offers
Contact info: 913-223-4418 jay text/call
Prior Salvage Title - back in 09 no wreck just hail damage -
shoot me a offer, looking to sell or trade for Honda Civic, Acura Integra 2/4 door, Lincoln LS , open to all offers jut let me know what you have.
Location; 66112
Year: 2000
Make: Lincoln LS
Model: 4door sedan
Pros-
6 disc changer
Premium sound
Cons-
Performance -
Handling -
Four-wheel ABS
Immobilizer
