WTF, trim won't go back on.
tonyd
St Kitts
The trim piece around the ashtray/heated seats won't sit properly after installing my new HU. There is a gap by the ash tray and passenger seat heat.
you have to play with the gaps, when you installed your HU, you tightened everything above the ash tray up, creating a bigger gap at the bottom. If you create small gaps in everything, it should line up again.
so should i lightly fit everything first? i will go f-around with it somemore.
Thanks
