WOT blues
ssmoparviii
Phoenix
So Im driving home from work this morning and its a nice cool morning out since the Valley got dumped on with rain last night. I had the windows down and was enjoying the weather and wanted to hear my engine roar so I put my foot into it. When I put the peddle to the floor the Mark stumbled and did nothing until I back out of it a bit. Then I slowly started step on it and got the check engine light... I will pull codes when the engine cools and I get some rest. But any ideas on what could cause this?
You need to replace your -insert bad part here-, that should fix it
Did you ever pull the codes and see what they were?
Yes I did they are all codes for the O2 sensor not doing its thing. They were 175,176,177,181,189. Then the wonderful code of 524. So I am will be replacing the two O2's and it looks like a fuel pump will be in my future. But Im going to try for the relay first.
Solved problem... Cleaned the MAF and used Sea Foam on it today and she is back to normal... Sea Foam ROCKS!!!
