Wiring Question
broggi007
Atlanta
Hello All,
Hopefully someone can point me to a tech article or somewhere else it's been explained. I am planning on getting Angel Eyes on my LS and wanted to wire them to a switch inside the cabin. What is the BEST way of getting the wires close to the driver for switch mounting... All experiences welcomed!!
Matt B.
Ever changed your fuel filter? Removing the inner fenderwell cover on the DS side should give you a good access point to drill a hole low in the firewall. If you dont want holes near the fuel filter (like I didnt) you can drill through the floor. There are also rubber plugs in the rear floor pan that go straight out under the carpet. If anyone knows how to get through the firewall chime in because I couldnt find one.
