firemanls
Havent been on here in awhile and wanted to come back and ask about some things i need to do to "winterize" my ls. Im in a little bit of a bind with court costs and then christmas is coming so i cant really dedicate my money to fixing the ls. Problems are the alternator needs replaced, and coils and plugs. as well as the foam seals to stop the water from getting to the coils.
So my car will probably be sitting for the next 2 months. Anything i should do? i live in tennessee so no worry about it getting under 10 degrees. I started it the other day with the battery charger on it and let it warm up and moved it up the down the driveway a bit to get the fluids moving through it again. anything else that you would recommend would be greatly apperciated. Thanks!
