Palmettokid
The driver's window regulator is giving me fits trying to get the window to travel smoothly. I had to reglue the brackets onto the bottom of the window recently. After reinstalling the window I noticed that the front edge of the window lags behing the back edge when I raise or lower the window. You can also take the window and tip it back and forth in the window tracks. It appears that the regulator is worn so that it doesn't raise the window evenly from front to back. If my theroy is correct can the regulator be rebuilt? Where can I find a replacement regulator? What should I look for if I need to get a used regulator.
By the way:
1994 Continental
Executive
By the way:
1994 Continental
Executive
