mmm
I replaced my passenger window regulator on my 03 LS today, but I am having issues with the window rolling up and down. I have read many threads and haven't found any with the exact issue I am having.
So the install was not difficult at all, but did take a couple of hours. I had to remove the window motor from my broken regulator and install on the new regulator. I replaced with dealer part #WLR-65
My biggest issue is that when the window is rolled all the way down, it sticks out above the frame about 2-3 inches. I attached the glass to the clips on the regulator correctly and as far down as possible.
Has anyone ever had this issue with a regulator install??....Does the motor have an actual mechanical stop where it can only travel one direction so far or is it able to completely spin freely as long as it doesn't "see" resistance??
I also am having trouble with the Auto up feature when rolling up my window...it rolls completely up and then comes down to about 3/4 and stops. This I know (from reading posts) has to do with needing to reinitialize / program the motor. I have tried the program instructions: roll all the way down, and then all the way up holding for 2-5 seconds, but this did not work. I have also read that I may need to remove the motor from the regulator and hold the up button and then re-attach. I have not tried this, because this means completely taking the regulator back out. I have also read that disconnecting the battery might help.
Can the auto up feature also affect how far down it will roll the window??
if anyone has any suggestions, let me know. thanks.
