Window not rolling down but motor is?
marco93L
Oklahoma
The rear window on the driver side is not rolling down with the motor. You can lower the window but it stays up, if you start to push it down, it falls down to where the track is.
How is the window attached to the track? Glue, bolts, ect?
Thanks for the help
Thanks for the help
Wow, you're on a roll today. You have two of the more common LS problems. Some simple searching should have given you the answers.
1. Your DCCV has failed and should be replaced.
2. You window regulator has failed (the plastic pieces break) and should be replaced.
There are even instructions posted on how to do both, some with actual pictures.
searching is so 1990, in today's instant fix society, people would rather make useless new threads about stuff that has been covered in detail in the past and take the risk of not getting all of the information they need, instead of spending a little research time and discovering all the info they need and more all by themselves and clogging up the search feature even more than it already is.
trust me, you dont win a prize for being the 1,000th member to create another thread about the same old sh!t.
put the time in, and do the research for yourself!
I agree with you guys. Mayabe someone need to create a how to on searching for information in a forum.
it basically comes down to people dont want to invest the time, because i have had no problem finding all the answers to any problem ive had by searching, sometimes it did take a few hours of looking to find what i needed, but it was all there and just needed to be waded through.
